- English
- Cameras
- How to get spotlight only triggered when activity ...
How to get spotlight only triggered when activity in the activity zone
I have the activity zone configured to only cover outside the door (Under Video->Activity Zones.
"Highlight areas in your camera view`s where you want to receive motion alerts"
But the spotlight is turned on when you activity way outside this area. Is there any way I configure this so the spotlight is only enabled when there is an activity within the activity zone?
No. The camera has to capture video in order to tell where the motion is (as the motion detection just sees a change in IR reaching it). So it needs to turn the spotlight on, and then discard recordings/notifications that are out of zone..
Ok, thank you. I assume I can try to tilt the camera more downwards to avoid triggering the spotlight too much far away.
Yes. You can also try reducing the motion detection threshold.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
