Hi
this option to disable geofence notifications does not work, i see that there's been a lot of discussions around this in the past, but what's the current status?
i have turned off notifications for geofence activation on android 10, but i stil receive notifications for every camera.
this is very annoying.
it's consistent, but yesterday i found a setting under the modus setting per camera
modus>geofencing> Push notifications
is this setting just for geofencing or is it all push notifications for the camera?
erlend_oyen,
Is this an intermittent issue or are you able to reproduce this consistently?
erlend_oyen,
This setting is just for Geofencing.
ok, that setting did work, so i can use that, but it would be beter to just use the notification settings on the phone.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
