Essentials spot light camera
I am planing a trip, I have been broken into last trip, I want my landlord to view my camera, Live feed and Notification, What subscription and Path do I take to get this accomplished Full Access..
Account Access ?
WiFi account Access?
I have tried inviting them NO Connection,
VIOLATED
No subscription needed.
Does your account show that the invitation was accepted? Or is it still pending?
Do you see "Library" at the bottom of the app screen? Or do you see "Feed"?
If you see "Library" then you would need to migrate your account to "Feed" in order for the landlord to see the recordings. "Feed" is quite different, and still somewhat buggy.
@Timothy63 wrote:
I am planning a trip, I have been broken into last trip, I want my landlord to view my camera, Live feed and Notification
If this is temporary (just for the trip), then one possibility is that you could just give the landlord your account credentials. Then change the password when you get back home.
The disadvantage is that there can only be one login at a time. So if you log into the app while away, the landlord would be logged out (and vice versa).
Thank You for your responce
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
