Hi.
My camera just shows an image of an electrical plug on the app where the symbol of the battery should be, and i can only set up the camera while its plugged into the USB, and as soon as I pull out the lead the camera turns off.
Basically it won't charge up.
When I last synced it, it said it was doing a firmware update, so I assume its done.
It's either that the battery is dead or the camera is faulty. I can't guarantee this will help but it's worth a try.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
Otherwise, use the app to go to Settings, Support. Select your camera and scroll down to Contacts to start the process for a possible RMA.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
