- English
- Cameras
- Re: Essential XL W/Spot light direct motion but wo...
Spoiler
A tad frustrated here. I currently have two essential xl cameras with spot light along with three 1st gen Arlo cameras.
the problem is the newer essential cameras all of a sudden stopped recording and now will only direct motion. I’ve done everything from start from new remove all devices etc, start restart only the two not working, added a 2GB usb drive to record locally. I’m three mins from tossing this hub in the trash. I went into HUB settings to select record etc, individually set settings on cameras.
Also why am I getting a ! next to record video here.
What’s funny the original cameras work fine. As tech seems to improve it doesn’t.
Hello,
It sounds like the trial subscription ended on the two essential cameras.
Local recording features depend on the base you have. There is a VMBxxxx label on it - please check it and post back on what you have.
BTW, a 2 GB flash drive is too small, Arlo requires a minimum of 16 GB. Generally 128 GB-512 GB is more than enough.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
