I saw a similar post on here about this issue but it did not have a resolution. Both of my camera's will not charge. I have used three separate outlets and had both plugged in for 12+ hours. I am using the charging cable provided and a 5V 2amp adapter.
Yeah, I already had the most up to date firmware. So I dont know why I was have that issue. I had to re-sync my camera and the issue resolved itself.
Just found another post about updating the firmware. Be back once I figure out if that's possible at the moment.
Likely not.
If you have a subscription (paid or trial), you can contact support. Use the support options in the app - one should be phone support.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
