  • 2547 Views
Volcaniac
6 month old Essential Outdoor Spotlight will not factory reset. Removed camera from account. Following instructions, held reset button 15-20 secs, got blue LED blink followed by only 1 amber LED blink (_not 3 as instructions stated_). Holding reset button through the LED blink sequence. About 1 min afterwards, get blinking amber light every 15 secs, so camera didn't power down. Holding reset button for 1-2 secs (supposedly to power on) only gives an amber LED blink, not blue. Have tried this 5+ times, with no success - only get single amber blink after blue LED blink, not 3 as needed.
How do I force this camera to do a factory reset so I can try reconnecting to WiFi? Was working fine for 6 months!
The slow amber blink usually means the battery needs charging. Plug it in to charge. While charging you should be able to reset and onboard again since it's drawing power via the charger.
Volcaniac
Thanks, that worked - apparently the camera wouldn't reconnect to WiFi with 61% charge remaining - had to recharge to 100% for successful reconnect.
Since the amber LED was blinking, I suspect the camera wasn't really at 61%. There have been display issues with battery level in the past.
