- English
- Cameras
- Do all cameras have to be connected to the same ne...
Do all cameras have to be connected to the same network?
I know I can run multiple cameras on a subscription. Do they all have to be connected to same network. Can I have multiple cameras in multiple homes on one subscription
Yes but...
If you're using the old user interface (UI) that uses Library to view videos, multiple locations are supported with no impact other than the total number of cameras (for legacy cameras, Pro 2 and older) while the new UI that uses Feed to view videos supports multiple locations but requires a separate subscription for each location. In either case, cameras newer than the Pro 2 still need a subscription for cloud recordings.
Describe your anticipated layout with camera models and numbers in each location.
Thanks for the reply. My app says library. I have the essential outdoor cameras. I recently purchased and am waiting on the ultra hub, which will be located at my location. I have several extra cameras that I want to put at my moms house which is in another state. I have 5 at the current location and want to put about 3 at another. So I should be fine. Thanks again for the help.
You might find that you will need to set up a different location when you are eventually migrated to "Feed". That would need a second subscription.
With "Feed", you are limited to just three built-in modes, with no custom modes possible. These three modes are per location, so they control all the cameras (unlike "Library", where the mode applies to a hub). You can edit all three modes, but you cannot add any new ones. So you might not get all the controls you need for both sites.
BTW, if you are planning to set up a friend account, that account will default to "Feed". You'll need to migrate your account to "Feed" to get that to work.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
