I searched this forum and didn't find an answer to this particular problem.
I recently had an issue with Arlo notifications that I couldn't correct, so I decided to uninstall, then reinstall the Arlo app on my Pixel 7 phone.
Every seemed fine after that, but it brought a new problem.
Now, every time I receive a notification, I also get an intrusive popup on my phone's screen, that appears over top of everything else.
I can't for the life of me see where to turn these popups off.
Can anyone give me a clue? TIA
It would help if we knew what the pop-up message is as well as whether you're using the old user interface (UI) that uses Library to view videos or the new one that uses Feed.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
