- English
- Cameras
- Re: Continuous charging of Arlo Essential camera
I have had my Essential camera hooked up with a solar panel for a month. On sunny days it maintains the charge fairly well but after a week of cloudy days the charge just kept on dropping. I didn't want to keep worrying about pulling out the ladder to get the camera to charge it. I purchased a longer charging cable and drilled a hole through my siding into my living room; ran the charging cable through to an electrical outlet in the living room. Perfect! Camera stays at 100% green battery. My question is: Will this hurt the camera in any way since it is always charging (green battery icon)? Does anyone know?
@lusterav Most other Arlo model cams can use outdoor AC Cables made for them.
lusterav,
While having a charger always connected should not cause any issues, Arlo Essential cameras are only designed to be powered outdoors with the compatible solar panel. The solution you've found here could result in water damage to the camera or the charging cable and is not recommended.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
