  • 8 Replies
  • 2878 Views
TimCNZ
I have purchased a 4 pack of essential spotlight cameras and am running a 3 month trial subscription. Only 2 of the cameras show in the manage subscription screen (they don't even show as inactive) and nor do they show in the Manage Arlo Smart screen. They do show on the app and I can see them live.  I cannot see library footage. I have tried to re-install them but this doesn't solve the problem. How do I get them added to the subscription?
TimCNZ
I spoke to Arlo support and they guided me to the solution
8 REPLIES 8
Tagging the mods ( @JamesC and @ShayneS ), to see if they can help.
Is there any chance that these cameras were returned by someone else (perhaps you purchased them as recertified or open-box)?
ShayneS
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
TimCNZ
They were new purchased from a reputable retailer
TimCNZ
All it does is ask me to purchase a plan. Why does it not wok with trial plan? How do I know it will work with purchased plan?
Did you reach out to support using the options in the app?  Pick a camera that did onboard - then you should see a phone option.
TimCNZ
MarcellRN
what was the solution?
TimCNZ
Found that 2 of the cameras were set up by another staff memer on a separate account so he shared the with me
