Can’t delete videos
How to delete videos from the Arlo app after deleted from USB in smart hub?
How did you delete them from the local storage? Try formatting the USB stick (or microSD card), and see if that works.
Hello - I can delete them from the USB drive, but not from the App Library. Since deleting them from the USB drive, the videos still appear but say not available. I want to remove them from the library.
I think there is some metadata on the USB drive - if so, just deleting the video file isn't enough. That theory is consistent with the videos appearing in the list, but saying "not available" when you try to download them.
That is why I suggested reformatting the drive - then checking that that the videos no longer show up.
Hi, I reformatted the drive and the videos still appear on the specific date within the app. Even when I remove the drive from the hub, the link to the images on the specific date still appear. What I need is an option to remove videos that are not needed instead of waiting to overwrite them. Is there a video delete option that I am not seeing?
Have a great day!
Arlo doesn't support deleting videos from local storage.
The local storage was removed, I want to remove their links from the app after they were removed from the local storage.
Did you try clearing the app cache?
Can direct me on how to clear the cache?
I don't have an Android phone. But there is a guide here:
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
