  • 10 Replies
  • 1233 Views
Saki4420
How to delete videos from the Arlo app after deleted from USB in smart hub?
10 REPLIES 10
How did you delete them from the local storage?  Try formatting the USB stick (or microSD card), and see if that works.
Saki4420
Hello - I can delete them from the USB drive, but not from the App Library. Since deleting them from the USB drive, the videos still appear but say not available. I want to remove them from the library.
Videos from local recordings have to be downloaded to your phone.  There used to be a setting in the app to delete those downloaded videos but darned if I can find it now. @JamesC , @ShayneS , @BrookeN ? Was this removed?
I think there is some metadata on the USB drive - if so, just deleting the video file isn't enough.  That theory is consistent with the videos appearing in the list, but saying "not available" when you try to download them.
That is why I suggested reformatting the drive - then checking that that the videos no longer show up.
Saki4420
Hi, I reformatted the drive and the videos still appear on the specific date within the app. Even when I remove the drive from the hub, the link to the images on the specific date still appear. What I need is an option to remove videos that are not needed instead of waiting to overwrite them. Is there a video delete option that I am not seeing?
Have a great day!
Arlo doesn't support deleting videos from local storage.
Saki4420
The local storage was removed, I want to remove their links from the app after they were removed from the local storage.
Did you try clearing the app cache?
Saki4420
Can direct me on how to clear the cache?
I don't have an Android phone.  But there is a guide here:
