- English
- Cameras
- Re: Can I mix a 1srt and 2nd generation Arlo Essen...
I have 2 Arlo Essential cameras, one a 2030 and the other a 2032. One has quit entirely--I don't know which. When I go for a new camera, can I mix the 2nd generation Essential Spotlight cameras with my old one?
The 2032 is the XL version with a larger battery, so it is easy to tell the difference.
Yes.
The bad one is the XL. I believe the battery is not replaceable, right? and I need a new camera?
Correct
If the camera charges, you could try the hardware reset
- remove the camera from the account
- hold the sync button until the camera LED flashes amber ( ~ 15 sec)
- add the camera back to the account.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
