I am wanting to arm my 2 cameras outside nightly. And have my inside ones unarmed. Is there a way to do this. I would like to activate the 2 each night from 9pm to 4.30am and have the spotlight activated and record any activity. Is there a way to do this?
@nzraider wrote:
Hello. I have 2 spotlight and 2 XL. Have 2 inside and 2 outside. Currently using geofencing and a schedule overnight.
Yes.
If you have a base, then create an outdoor mode (that only has rules for the outdoor cameras). Then schedule that mode.
If you don't have a base, then you will need to schedule each of the outdoor cameras separately.
Note that either way you will need two slots in the schedule (9pm to 1159, and midnight to 4:30 am). The schedule won't let you create a single entry that spans midnight.
Yes.
Brilliant. Thank you. Have a base station. Works perfectly.
I can now get up during the night to have a drink and not set them off!
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
