  • 6 Replies
  • 2865 Views
007mike
Arlo essential Blue light stops blinking while app is trying to find the device.
Is it rapidly blinking when the light disappears? That means it was found. Slow blue blinks followed by rapid amber means not found.
6 REPLIES 6
007mike
It flashes slowly then when I press continue for app to find device, 3 seconds later it flashes amber once then lights go off
Is the battery fully charged?
007mike
Yes it's fully charged, as I had it charging for 2 days. I've even tried it while it was being charged. The bug light blinks slowly for 77 seconds them the led changes to orange, blind for fast for about 5 seconds, them led goes off. How do you know if its fully charged?
When charging, the blue LED will show solid blue when the battery is fully charged.
007mike
Ok thanks. I just realised the problem. The vpn was on, on my phone. Thanks for your help though 👍🏾
