- English
- Cameras
- Arlo essential spotlight camera wont hold a charge
My camera shows a blue light when plugged in to charge but after unplugging the light goes off after about 15 seconds. This camera is also offline so I'm unable to check the status.
Thank you. I called support and they are sending me a replacement.
The camera blue LED only shows solid blue when connected to power and the battery is fully charged.
I'd suggest removing the camera from your account, reset it and connect it back again as shown in the following FAQ:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
