  • 1 Reply
  • 1844 Views
Scot71
Hello,
Bought my mother the Essentials cameras for her house not knowing there would need to be a subscription for that one after the trial. I have the pro2 that came with a rolling 7day cloud storage so I assumed hers would too. My mistake. Can I buy a hub for her for storage or is she stuck with the subscription only? Thanks.
DannyBearAgain
If you’re mother is elderly you would be best to use the subscription plan for cloud storage.
The article for using local storage is below,
read carefully about limitations.
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it-for-Arlo-video-recor...
