Hi folks,
I've been using this particular Arlo camera as a portable/mobile security camera, but the tripod threading seems to have fallen out, so I have no good way to quickly mount the camera to a difficult location using a flexible tripod.
I purchased what I thought would be the right kind of adapter (Standard 1/4"-20 Female to 3/8"-16 Male Screw Adapter, says Amazon), but it's just the tiniest bit too big to fit in the space on the Arlo.
Can anyone guide me to the correct piece?
Thank you!
David in Athens, Ohio
Thank you!
The space on the camera should be tight since it's a press fit (so it doesn't fall out by itself). A little bit of shaving of the plastic may help but make sure it goes all the way down to the same degree. I suppose some light filing of the insert could also help.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
