Arlo Essential wire free spotlight security camera VMC2030
  • 2 Replies
  • 2471 Views
Medgas71
Printed off instructions off support for reset of field of view and it says tap devices on Arlo App on phone, then tap devices find your camera and tap settings, don't see symbol for settings all it does is go through the set up operation for the camera.
Help,
Steve
Do you see "Library" as a menu choice in your app?  Or do you see "Feed" and Dashboard" instead?
To be clear, the VMC2030 only has one field of view (130 degrees).  That cannot be changed.
What you can do (which is very similar) is zoom the image you see when you are viewing the live footage.
Medgas71
Thank you,you stopped me from going crazy!
Medgas71
