- English
- Cameras
- Re: Arlo Essential wire free spotlight security ca...
Printed off instructions off support for reset of field of view and it says tap devices on Arlo App on phone, then tap devices find your camera and tap settings, don't see symbol for settings all it does is go through the set up operation for the camera.
Help,
Steve
Do you see "Library" as a menu choice in your app? Or do you see "Feed" and Dashboard" instead?
To be clear, the VMC2030 only has one field of view (130 degrees). That cannot be changed.
What you can do (which is very similar) is zoom the image you see when you are viewing the live footage.
Thank you,you stopped me from going crazy!
Medgas71
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
