Arlo Essential live view lag
I just installed this camera and am having extreme lag on the live view. My phone actually shuts the screen off before live view shows up. This is the SECOND Arlo camera I've landed that seems absolutely useless. I was hoping the first one was a fluke.
Has there been a fix for the lag?? I don't have connection issues as I use a mesh network, one is right by the door, have minimum 400Mbps upload and download, and both my app and camera software are up to date.
I have a Ring outdoor and ring doorbell for comparison and have zero issues with lag. Is there a fix or is this something I have to return? I will never buy it recommend an Arlo product again if there isn't.
I have about a 3-5 second lag on my essential and pro3's. I had a Ring stick up cam and that had about the same or longer lag.
Just to add that is on my tablet, on ios app its 2-3 seconds lag.
JOcean,
Do you also experience this when using the web client?
Is the camera connected to a Base Station/SmartHub or is it connected directly to your home network?
It's not connected to a base.
Thanks.
I have the same issue. Some comes and goes before I connect. Notifications are also delayed. This setup seems to be more of an after the fact system.
@JOcean wrote:
I haven't tried in the web client, but it would defeat the purpose if I have to use my laptop since I'm already home. I could try a browser on my phone but again, it's a workaround for something that shouldn't be an issue especially for such a large company and when smaller companies don't have this issue.
It's a troubleshooting tool. If it works on one but not another, that's a clue.
Notifications can be delayed due to use of Arlo Smart which has to post-process the video before sending the notification. If you deactivate the camera in Smart Notifications do you get relatively immediate notifications?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
