Arlo Essential XL with VMA3600 Solar Panel – doesn't charge?
  • 1 Reply
  • 2284 Views
fbennien
Hi Arlo tribe,
I just bought the Arlo Essential XL in combination with the solar panel. However, it looks like the panel is not charging the camera/battery. Can anyone help?
When I connect the camera to the charger I get a little charging arrow in the battery symbol in the app – like with my Macbook and other devices. However, when I connect the solar panel, I don't get this arrow.
Questions:
1. Is the arrow visible in the app when the solar panel is connected? Or just, if the panel is charging? Should it show at all?
2. How bright does it need to be outside for the panel to charge? Just a normal day? Or does it need bright sunlight?
3. How fast should the panel charge the battery? I.e. mine was delivered with around 60% charge and has not changed much in the first three days ...
4. How can I find out if the panel is not working vs. there is not enough light?
Thanks for any help.
Best, Felix
The lightning bolt will only show up when the panel is delivering power.  The camera is detecting the power, so if the panel is totally broken you shouldn't be seeing the lightning bolt at all.
The XL is a big battery, so it will take a long time for the panel to charge it.  I suggest fully charging it with the AC adapter first, and then see how well the panel can maintain the charge.
