  • 8 Replies
  • 2180 Views
  • 6 In Conversation
DarnellM
Ever since I got my second Arlo Essential Spotlight Camera, it disconnects fully and I have to reset it and re add it to my profile. The charge is at least 60 % so I know it is not the battery level. I do have another Arlo Essential Spotlight Camera and it is farther away so I know the signal is fine for the closer one.
8 REPLIES 8
Have you tried swapping the cameras?  Then see if the problem stays with the camera or with the location.
DarnellM
Yes I have, same issue same camera.
Is the camera still under warranty?  (one year)?
Also, is it newly purchased (still in the return window for the seller)?
CaspaArlo
Same issue. Camera keeps resetting itself.
CaspaArlo,
Could you provide more details? What exactly is happening when you say the camera keeps resetting itself?
DarnellM
With mine specifically, the camera will remove itself from my account and not be responsive or be discoverable. I have to take it down, do a hard reset, rediscover it, go through the whole process of re adding it to my app and then re add it to my account. The camera is connected to a signal booster with one other device.
Greeba
How do you do a hard reset on the Essential camera?  I have 2 red lights at the top of my camera & the blue light will not come on when I push the sync button.  We have 2 other cameras that are working fine
Here's the reset procedure:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Having the IR LEDs on and no response to the sync button seems to indicate a faulty camera. Either swap at the store or use Settings, Support to start a possible replacement.
