  • 1887 Views
CA16390
Is the Arlo application for outside wirefree cameras available in French language?
CA16390
Hi, sorry for delay in responding.  I have now set up the camera and can confirm that the Arlo app comes up in French as default when installed on a French smartphone.  Thanks for your support.
I believe the language used is dictated by the device that set the camera up. Thus, French is supported but would need to be selected to be in use when setting the system up.
CA16390
Thank you, I will be setting up a new device for a French neighbour, so I'll see how that goes and respond then with the result.
CA16390
