Is the Arlo application for outside wirefree cameras available in French language?
Hi, sorry for delay in responding. I have now set up the camera and can confirm that the Arlo app comes up in French as default when installed on a French smartphone. Thanks for your support.
I believe the language used is dictated by the device that set the camera up. Thus, French is supported but would need to be selected to be in use when setting the system up.
Thank you, I will be setting up a new device for a French neighbour, so I'll see how that goes and respond then with the result.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
