  • 11 Replies
  • 2618 Views
SireeshaDadi
On my pixel 8 pro, the app crashes as soon as I open it.
Cannot access any settings or any cameras. I hasn't even been two weeks since I bought the cameras
https://drive.google.com/file/d/18XGwtA1N0Q_3DPbVgk1852rN9uY8HOLJ/view?usp=drivesdk
11 REPLIES 11
BrookeN
Have you tried uninstalling and reinstalling the app? What software version are you running on the Pixel 8?
SireeshaDadi
Yes I have tried that several times
Disregard.
BrookeN
Are you still seeing this same behavior?
SireeshaDadi
Yes!! I am hoping to return this set. It has been useless since day 1 as the app crashes.
FYI I am using the beta version android on my pixel
That is why (a known issue with the beta).  Have you considered just switching to production Android?
SireeshaDadi
Well changing the phone to production version requires a full reset. Every other app in the market works fine, its just this one that crashes.
No way you can know that, given that there are over 3.5 million apps in the Google play store.  It's not clear whether this is something Arlo can fix (or work around) or whether Google needs to fix it.  The whole point of public betas is to allow Google fo find and fix their bugs.
As I said above - this is a known issue already reported here, so Arlo is aware of it.
BrookeN
BrookeN
This should have been resolved with a Beta firmware update. Are you still seeing this behavior?
SireeshaDadi
No this is resolved now. Thanks!
