  • 7 Replies
  • 3977 Views
Joopnoordzij
The amber indicator light on the camera stays on in a sort of low output mode, it does not blink. I already reset the device several times to no avail. The light drains the battery, so how do I get it off?
7 REPLIES 7
This post is in the Essential camera series section but you indicate that it's an original wirefree camera which has 4 CR123 batteries.  This can't be reset by anything other than opening and closing the battery door. Verify the camera model so we can be accurate in responses.
Joopnoordzij
It seems to be an essential spotlight camera with onboard non-removable batteries.
The four LED patterns in the user guide are
  • Slow blinking blue. The camera is in the process of pairing to a WiFi network.
  • Fast blinking blue. The camera paired with a WiFi network.
  • Blinking amber. The camera is out of range, a connection error occurred during pairing, or
    the camera battery charge is low (15% or less).
  • Alternating blue and amber. A firmware update is in process.
So solid amber isn't listed.
Is the camera operating normally (other than the fast battery drain)?
How often are you needing to recharge it?
Joopnoordzij
Hi Stephen,
The camera seems to be operating normally. The battery drains at about 3 percent per day on standby, so it will probably not last a month. It used to last about four months.
Is it still under warranty?
I am wondering if the drain is reduced (or the LED status changes) if you bring the camera closer to the base (or router).
Drain does depend on temperature - all batteries are much less efficient at low temps.
Joopnoordzij
It’s about ten months old, so I guess it is still under warranty. Maybe I should send it back?
I have two of those cameras beside one another so they cover the entire back of the house. They are both only 15 feet from the router/ WIFI transmitter.
Should I contact Arlo?
You could try swapping the two (switching their fields of view), and see if that changes the battery drain.
But since you are seeing the strange LED status on one camera (but not the other), you could just contact Arlo and ask for an RMA.  Use the support options in the app (googling for support usually lands you on a scam site).
