- English
- Cameras
- Re: AVD2001 Video Doorbell Wire-Free Failed to Upd...
I have a Essential Wire-Free Doorbell Camera that seems to have issues every time I have to remove the battery to charge. The latest issue it's having now is it will not return to Armed mode. I keep getting a message stating "Failed to Update Automated Definitions". I've tried resetting the camera with no results. Does anyone know who to correct this so I can get the camera back to working again?
I suggest removing the doorbell from the account and setting it up again. Once the doorbell is removed from the account uninstall and reinstall the app, reset the doorbell, open the Arlo app and proceed to set the doorbell up again. After it is set up, check to see you are able to use the Armed mode.
Thanks for the suggestion. I removed the doorbell, reinstalled the app, then set the doorbell back up and it is now working again. I was hesitant to remove the doorbell from the account, because I've had to do that before, and each time the doorbell would not reconnect. This time it reconnected without issue.
Glad to hear it is working. Have a great day.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
