Camera VMC2030 keeps saying high temperature or low temperature
  • 2148 Views
Paulh2808
Camera has been working fine for a couple of years but I noticed that it initially stopped charging from the solar panel. Then I got a message in the app saying that the temperature is too high and the camera stopped working. This now seems to alternate between the temperature being too high or too low or the camera actually working! This happens in perfectly normal temperatures.
Suggestions?
Paulh2808,
Try removing and re-syncing the camera. Do you still experience the same behavior?
Blairk
Hi, I am having this problem with the “temperature is too low” warning. Have had the device for 3 years and worked fine until a couple of months ago. Tried the reset and reinstall several times and it still goes to the same problem within 24 hours. Live in New Zealand and the temperature is between 10 overnight and 23 degrees Celsius during the day so it isn’t cold.  What else can you do if the reset isn’t working?
It's out of warranty so all you can do is replace it - there's no replacements nor service possible.
