ARLO SECURE PLAN FOR ARLO SMART HUB
With the $9.99 Arlo Secure Plan can two family members be in the arlo website at same time? Currently, if I am in the app it shuts down if you husband is elsewhere and logs on. This is aside from the invite I sent - which he accepted. But again, I would think that if I am in Florida and he's in CT, we would be able to be on at the same time. Am I wrong?
This implies that the two of you are using the same login credentials. It seems like you're the owner of the cameras (primary user) so he, as a guest account, should log in using the credentials he supplied when accepting the invitation. That way, both of you can be logged in at the same time.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
