@Rokho wrote:
I'm getting very short recordings, and when following the steps to set the recording length to a preset time e.g. 120 seconds, it doesn't save and defaults to stopping recording when it stops detecting motion. Is this a known app bug?
When adjust the recordings length are you hitting the "back" link and then the save button on that page? It may be easier on the web portal.
It would be easiest to reboot the phone and reinstall the app to see if that helps but you may need to remove (maybe also reset) and resync your doorbell.
Rokho,
This could be a symptom of limited internet bandwidth or poor signal strength. What are you download/upload speeds? What does the signal strength icon show for your camera?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
