aussiemart
I have 2 essential indoor cameras that keep go offline within 24 hrs they are  permanently plugged in and one is next to router. I have 13 cameras of various arlo models and these are the only ones I have issue with. I have to unplug and plug them back in every time I need them to work.
Best answers
  • BrookeN
    Just a quick follow-up you may all notice that your firmware has updated or will be updated to version 10.1.7_23ee515. That is the permanent fix for the behavior you were seeing with the E2 cameras. If anyone see's this behavior after the firmware update let me know.
  • BrookeN
    The development team is currently investigating a recent firmware release that has resulted in a small number of users experiencing intermittent offline behavior. We will continue to work with users who experience this issue by rolling back this firmware update to alleviate the offline symptoms. We apologize for any frustration this issue has caused and hope to provide a full resolution soon.
148 REPLIES 148
ScottAndo
This has also happened to me recently. 4 Arlo essential indoor cameras connected to wifi that go offline roughly every 24 hours in the last month or 2. Worked perfectly for 6 months prior to that. We have about 9 other Arlo devices all connected to wifi that all work perfectly. I’ve tried everything I can think of (hard resets, various wifi network settings and configuration) without success. As others have suggested this points to a firmware issue. Request that Arlo please investigate and fix as seems issue is affecting many users.
BrookeN
We are currently investigating this behavior you are seeing. I will provide an update to the community soon.
BrookeN
timo_h
Thank you for the update. Has the firmware already been rolled back? I've restarted my cameras but they still remain on the same version. Is there anything I should do to roll them back?
Bart1963
Hi timo,
2 of my 3 essential indoor camera received the rolled back firmware last night. The other one was, like yours offline. I’m guessing the updates are sent out once a day. So try and keep your camera online and it should happen within the next 24 hours.
timo_h
That's really good to know. Thanks for the quick reply Bart.
duqu
I’ve had Arlo for nearly 10 years now and have always had random issues but this one is now becoming the norm. My set up is fine. All cameras have been reset and work fine. From
one day to the next, from one hour to the next, they will randomly show up as “offline” then half an hour later it’s back online. they record when they want to, the cams sees when they wants to, there is zero consistency with Arlo and I’ve given up getting consistent camera security from them. I just use them to watch wildlife, and even then with the sensitivity set hi it acknowledges movement and records only when it wants to.
most likely I’ll be tossing these in the trash as they fail and using the other system (other brand) exclusively. in no way will I replace them with another Arlo cam as long as this random bs happens and those days won’t ever happen with this company.
aussiemart
Did you get the roll back my 3 cameras still have the same firmware that was the issue tried one on wifi went offline again within 24hrs. Might just stick to running through the base station as no issue since doing that.
Bart1963
Your cameras will need to be online, (maybe just wifi connection) I think that Arlo will push the rolled back version of the firmware once every 24 hours. All of my cameras are now working as they should and have exceeded 24 hours without any problems.
Deemarmail
Arlo have rolled me onto firmware 1.8.2_2317_bb2940a, which I can see has been applied. I've just restarted my cameras and going to set how it goes
aussiemart
Thanks have set them all to wifi see if that gets the roll back
Bart1963
Good luck aussiemart,
I’m pretty happy atm. I spent a lot of time chatting with Arlo support and altered nearly every setting on my router, which is the end was completely unnecessary.
fingers crossed.
aussiemart
No role back on any overnight is anyone on this thread from Australia that has received it?
Bart1963
Yes I am in Western Australia,
I have 3 Arlo Essential Indoor Cameras and all have been rolled back firmware and all working continuously for two days now.
Bart1963
aussiemart,
Apart from being on this Arlo community chat, have you lodged a support request with Arlo. Through their support centre.
Deemarmail
Yep, I'm in Melbourne. But Arlo contacted me privately to organise the rollback. I think they're just making sure it works for a handful (and without any side effects) before rolling it out to everyone.
But looking good so far. Been about 26 hours since I restarted and still up and working
MKNZ24
I’m in New Zealand and confirm my devices have rolled back from firmware starting with 10.0.2 to 1.8.2. This appears to have resolved my issues.
aussiemart
I received private message also couple of days ago still no roll back 😕
timo_h
I've had one of my two affected cameras rolled back and haven't had any issues with it since. Hoping the other one is rolled back soon too.
BrookeN
Thank you everyone for the feedback, I am glad to hear that so far it seems to be helping with the offline behavior you were seeing. @aussiemart I have rolled back 3 of the 4 cameras. I cannot roll back the 4th as it is offline.
CAP08D
May I know when the rollback firmware will be made generally available to all applicable users.
BrookeN
@CAP08D if you are seeing the intermittent offline behavior as well I would be more then happy to roll you back.
CAP08D
All of my Essential Indoor Camera 2nd Generation cameras (total 3 of them) are also experiencing the same issue. Please roll the firmware back for me. Thanks.
blurdude
My device (VMC3060Aer1.4) is also having this issue.
Current firmware is 10.0.2509_e400417.
Please help rollback the firmware.
BrookeN
@blurdude I have rolled yours back. Please give it 24 hours before rebooting the device.
