I have a pair of these camera’s and everyday they go offline for hours. I have reset, updated firmware and tried everything, but still to no avail. The internet signal is strong and the batteries are fully charged.
@Anthony456 and @Happyway I have moved all your outdoor Essential 3 cameras to the experimental build. You will need to reboot the camera to get the software onto the device.
By rebooting, do you mean re connect to the wifi? Or is there something else that needs to be done
Restart them using the app.
Press the camera settings on the video tile, then select device info. You'll see restart at the bottom of that page.
Hello any status on where development team is with a firmware fix? Yesterday installed these cameras and today experiencing already this kind of offline behavior.
Thx
I am also having this issue. Had the doorbell for years but these cameras are poor. Got them direct from arlo can see me sending them back and cancelling the subscription.
@Xanderxxx I can move the Essential 3 over to the experimental build if you would like. It should resolve the offline behavior that you are seeing. Please let me know if you would like me to proceed.
If you can move me over and it is stable that would be brilliant thanks
Alright, I moved both those over to the exp build. Please reboot the device in about a hour.
Brilliant thank you will let you know how it goes
