cameras are no longer charging
  • 1 Reply
  • 591 Views
34g
 Has anyone else had this problem? My cameras are no longer charging. The cable works perfectly because I tried it to charge a speaker. Can you help me with some advice? Thanks. 🙏
Did you let the batteries totally deplete? If so, try this FAQ - the trick is to plug in and unplug many times to get enough charge in the battery to allow it to then charge properly:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
