Can someone recommend mount unit and protective covers dark color) from Arlo or Amazon website.
None of the new camera use the original magnetic mounts. If nothing else, the magnet has been moved out of the camera and into the mount so they're not possible to use.
There's a threaded hole in each camera that can be used with a standard (1/4"-20 thread) camera mount available from many places.
Either way, the existing mounts will have to be replaced with a compatible mount for the new cameras.
stribor45,
You can take a look at the accessories designed specifically for Essential 2nd generation cameras here: https://www.arlo.com/en-us/accessories-essential-v2
The mount threading is standard 1/4-20 so any mount that supports that thread will work. Take a look at these here: https://www.arlo.com/en-us/accessories/VMA4000B-10000S.html
What do you mean? Currently I am using the mount that looks like a dome. I want to replace my existing pro 2 camera but hoping to use this same mount.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
