Wifi can't have special characters
Arlo -- you guys need to update your products -- it's a joke that a special character can make a WiFi network unable to connect.
I have a " - " in my WIFI name. This WIFI is connected to dozen of devices. I'm not about to reset because one product has poor programming.
I connected it to a different WIFI network without a dash in the name, but it's not as fast and isn't as close to the camera, so the connection is not as good.
It's a joke of a product if such a thing causes the entire product to fail. Please have your developers work on a fix and roll it out.
Did the camera fail to connect?
Or did you not attempt it because you thought it would fail?
Camera failed to connect, with a warning that "WIFI with special characters will not work" (or something to that affect).
My network has two WAP throughout which is named "Mynetwork-WAP1" (mynetwork not the realname, just using it as example). The camera instantly connected to the wifi called "Mynetwork" and had no issues.
The problem is that WIFI's router is quite a bit further that the WAP.
It's just extremely silly for a product that has such a good reputation to have such a poor point of failure.
FWIW, I agree.
My understanding was that dashes and underscores were ok, but some accented characters were not. They should fix that, and in the meantime should have a list of what characters are ok.
socool111,
I will raise these details to the dev team for further review. What camera model were you attempting to onboard and what router make/model are you using?
This was the Essential XL outdoor camera.
Router is Nighthawk AC26000, but it was through a WAP by Ubiquiti (Unifi 6 Lite Access)
Hi, was this resolved? I am having same issue connecting to WiFi that has a dash -
this is silly
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
