WiFi
  • 11 Replies
  • 5015 Views
Jetgirl
Why won't my camera show the available wifi when trying to set up??  I have 4 cameras on it but the 5th isn't showing.
11 REPLIES 11
Try resetting the camera (including removing it from your account if it shows there):
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
Jetgirl
It's a new camera.   Never been set up on my account.   The other cameras I checked link up to my wifi, this one doesn't show any wifi
How far away from the router is the camera?
I am wondering what you see if you just press the continue button???
Jetgirl
 this is as far as I get no matter if I am right next to the router or in my driveway
Pressing on the X (or on continue) doesn't work?
Jetgirl
Nothing works.  It stays on that page.
It could be a failed camera.  Did you try resetting it?  (hold down sync until the camera flashes amber - about 15 seconds).
Jetgirl
It is a new camera.  Not on the account.  It will not set up or connect to wifi
Did you try the reset I suggested?
SueKC
I just purchased an Arlo Essential outdoor camera, 2nd gen. I have older Arlo Pro cameras with batteries that you change out, and a base station for those. They work fine, but use up batteries.
I cannot connect the new camera to Wifi. The set up never gets to a point where it finds my Wifi to allow me to enter my wifi password. I have tried many times. I plan to return camera.
I have also tried to reset it, pushing the top button until it goes to amber. Nothing works.
The camera doesn't find the wifi - your phone is what does that.  Then after you select the wifi, the app sends the network info to the camera via a QR code.
Have you checked that
  1. the phone is connected to your home wifi
  2. that the app is allowed to use your wifi network?
