WiFi
Why won't my camera show the available wifi when trying to set up?? I have 4 cameras on it but the 5th isn't showing.
Try resetting the camera (including removing it from your account if it shows there):
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
It's a new camera. Never been set up on my account. The other cameras I checked link up to my wifi, this one doesn't show any wifi
How far away from the router is the camera?
I am wondering what you see if you just press the continue button???
this is as far as I get no matter if I am right next to the router or in my driveway
Pressing on the X (or on continue) doesn't work?
Nothing works. It stays on that page.
It could be a failed camera. Did you try resetting it? (hold down sync until the camera flashes amber - about 15 seconds).
It is a new camera. Not on the account. It will not set up or connect to wifi
Did you try the reset I suggested?
I just purchased an Arlo Essential outdoor camera, 2nd gen. I have older Arlo Pro cameras with batteries that you change out, and a base station for those. They work fine, but use up batteries.
I cannot connect the new camera to Wifi. The set up never gets to a point where it finds my Wifi to allow me to enter my wifi password. I have tried many times. I plan to return camera.
I have also tried to reset it, pushing the top button until it goes to amber. Nothing works.
The camera doesn't find the wifi - your phone is what does that. Then after you select the wifi, the app sends the network info to the camera via a QR code.
Have you checked that
- the phone is connected to your home wifi
- that the app is allowed to use your wifi network?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
