- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: When trying to set it up to my wifi I keep get...
When trying to set it up to my wifi I keep getting error codes and they can't find it in the system along with wrong password. I am putting in the right password. What is up.
Best answers
We're currently investigating reports from some users experiencing issues onboarding and streaming new devices. For more information and updates, see here: https://status.arlo.com/
We're currently investigating reports from some users experiencing issues onboarding new devices. For more information and updates, see here: https://status.arlo.com/
We're currently investigating reports from some user experiencing issues onboarding new devices. For more information and updates, see here: https://status.arlo.com/
I cannot the 2nd Generation Essential Outdoor camera directly to my Wi-Fi. I get stuck on “Searching for the device in our system” and then it fails.
I was told by customer support on the phone this afternoon that they expect to be fixed today 🤷🏼♀️
There is a known Arlo problem with setting them up. They are working on it
Yeah, “working on it” for almost 24 hours. Not a very good look considering they just sold a crap ton of these for the early Black Friday sale at Walmart.
True, but we have had Arlo Pro cameras (on end of life list) for a few years amd had issues. So I am hoping they will fix this quickly
Meant and had no issues
ShayneS, thanks for the reply. I have connected the Essential 2 camera to my main house WiFi router. Slow to load but it works fine. Ultimately I would like to mount this camera on a barn containing the VMB4000 hub that is 150' from the main house. I eagerly await the resolution to the hub compatibility issue.
I just got a Arlo Essential outdoor Camera Generation 2. Trying to set it up I hit the sync button on top hit continue in the app say connecting to wifi then it says camera failed to connect
I just bought a camera, and it is just «spinning» when I try to have a live view. When you fix the issue, is there anything I need to do, or will it get updates in the software online?
I just got a Arlo Essential Outdoor Camera 2nd Gen today and i have the app it finds the camera when i sync. it searches my wifi then it says searching for the device in our system. Then after awhile it says camera failed to connect. There was a issue when connecting please try again gives Error Code 17409. It keeps doing this everytime I try again. Should I just take it back to Walmart or what?
I cannot view live feed on my cameras.
Cannot go live, cannot cut cameras
off or on.
Do you know if other people are getting stuck at “trying to find the camera in our system” when trying onboard too?
I have the same issue. Bought 2 and they won't update or connect...supper pissed.
issue I’ve been saving since yesterday
My cameras record clips when they sense motion, like they are supposed to, but I cannot access the live feed. Access to the live feed is one of the main reasons I purchased these cams in the first place.
My Arlo Essential Camera, 2nd Gen, is not displaying any live footage despite trying various troubleshooting options, including moving it to a different location and performing a factory reset. Everything else, such as motion detection, the spotlight, and two-way audio, is functioning properly. Notably, when motion is detected, the camera successfully captures footage and identifies the cause of the motion, whether it's a vehicle, person, or animal. However, the primary issue is that the live footage, arguably the most crucial feature, is not working at all, and I have not found a solution.
I just bought Arlo Essential outdoor 2nd Gen Cameras and They keep giving a error code : 17153. I have been trying to connect all day. The Cameras are fully charged and I am setting up with my router only 3 inches away from everything. First time activating my account/cameras. Thank you
Thank you James. Please keep me apprised if the issue is resolved.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
