Onboarding fails at the last step - after firmware update both on wifi and via base station. I performed multiple camera factory resets, used different mobile devices, checked using 2.4 GHz same wifi network etc. There are no fault codes. I am out of ideas.
If you just continue does it show in your account, perhaps with a red "!" in the camera in Devices?
When trying to connect via Wifi, yes it does. When I select the red ! I am instructed to complete onboarding. This continues to fail as before. This is the screen in this case, this screen does not change - I have waited up to 30 minutes.
When trying to onboard via the base station, this below is the final fail screen: of course trying again does not change the result.
WHen you reset, did you follow this FAQ fully?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
If so, it may be a faulty camera. The fastest solution would be to swap at the store.
Thanks. Yes, fully c/w several times but no joy. Purchased on line so will apply for RMI.
I am having the same problem and getting extremely frustrated as EVERYTHING is brand new..I complete the setup ( it even tells me that ) and yet I'm still getting the error to finish the on-boarding when there's nothing else to do. When I hit the red error on the screen it keeps telling me to finish the on-boarding on the next screen.
My camera was bricked and Arlo replaced it free of charge, under warranty. I believe this is a known problem. The Arlo customer service person was helpful and efficient - she had to run through the on-boarding procedure with me agan to confirm the problem, then obtain permission for the replacement. My comment to the inevitable questionnaire was that she was great but the process of getting to her was painful and time consuming. I now have a working camera.
I am having this exact same issue with two new Essential Cameras Gen 2 and a smarthub. Smarthub hooked up easily, but the cameras are stuck in "Finish Onboarding". About to return everything! Wasn't going to purchase the smarthub, but saw an article that the Gen 2s were compatible after the firmware update in November.
FWIW, I onboarded a couple of E2 cameras the other day. One went flawlessly but the other consistently gave me the red "!" on the camera thumbnail to finish the setup. Regardless of what I did, it wouldn't go away even though I was able to complete the process. I gave up for the day but tried again a few hours later - and it worked! Now that some time has passed, try again to see if that works.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
