I have 2 second gen essential cams. How do I arm one and put the other on standby?
There are three options
- manually turn the camera off in the device settings (turning it on again when you want to re-arm it)
- temporarily edit the mode you are using to remove the camera from the mode when you want to disarm it. (adding it back when you want to re-arm it).
- edit the modes to repurpose them
The challenge with (3) is that there are four possibilties
- both cameras armed
- camera A armed and camera B disarmed
- camera A disarmed and camera B armed
- both cameras disarmed
Since you only have 3 modes to work with, you'd need to give up at least one of these possibilities. For instance, you can
- set up Armed Away as (1)
- set up Armed Home as (2)
- Set up Standby as (3)
And manually turn a camera off when you want them both disarmed.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
