Essential XL 2nd Gen Ceiling mount
  • 1 Reply
  • 1779 Views
C0pypaper
My home is brick and I'd like to mount my essential xl 2nd gen cameras from the underside of the soffit instead of going into the brick.  With the provided mount, I don't believe I'll get the angle necessary.  Is anyone aware of a ceiling mount available for this camera?
thank you
Check Amazon, etc. for outdoor camera mounts. Almost any of them will work since the cameras use the standard 1/4"-20 thread. You should be able to find something easily that would suit your needs.
