  • 1 Reply
  • 410 Views
arlouser120924
the solar panel Arlo sells for GEN 2…..SUCK
model, VMA6600
they are only 1.2 Watts, they don’t charge at all
they are useless, and DO NOT work
I've had no problems with a working panel to charge. They're trickle chargers so output is indeed low (I have rooftop solar panels which require a bunch to get a useful output - a single one would again only be a trickle charger).
If you have a problem with the panel, swap at the store. We may be able to help if you tell us all details.
