- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Rules turn on notification even after I've tur...
I have several Arlo cameras of different types. Yesterday I added a new Arlo Essential Outdoor 2nd Gen (called "Roaming") and set it up in my Away mode so that it records if motion is detected. It has a "Send Notification" section that I can't remove but I can't turn off the "Send to Everyone". However, it get automatically re-enabled after a few minutes.
My Front Door camera works as expected: it records and notifies. My other cameras work as expected: they only record. This Roaming camera can be set to only record, but then if I go back into the settings after a few minutes, it says Record and Notify again.
In the two screenshots below the Roaming camera is setup correctly, but then after a few minutes it changes back to Record & Notify. Any ideas?
Best answers
Thanks for your patience. It looks like this has been fixed with the latest version 6.3.8. Can you update to this version and test again? Please let me know if you still experience these symptoms.
The root cause has been identified and a fix for this symptom is being worked on. Thanks for your patience.
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
How long does it take to switch back after you change it?
Are you changing it in both Arm Home and Arm Away?
I haven't seen this with my own Gen 2, but I normally leave notifications on. I just disabled notifications in Arm Away, I'll check it again in a few hours.
Yesterday I turned on notifications for all camera due to some utility work being done on the property. Today I try to turn off notifications on a number of our Pro 3 and Pro4 cameras and the setting won't stay turned off no matter how many times I save or if I use "arm away" or "arm home"
Is this a bug with the last update? How do I get these notifications to turn off without disabling all notifications?
Same for me. Resets to force notifications immediately or very quickly. I don't want notifications during arm-home but I do for arm-away. This bug results in too many notifications when I am home.
Same issue for me. I have 5 cameras Ultra 2, and on 2 of them I can't turn notifications off.
I tried to delete cams et readd but nothing works
I have a similar issue and reported it to Arlo. The option to have notifications switched off is not saving in the app.
You can, however, successfully change whether or not you want cameras to notify you in the web version of Arlo Secure.
This is the only way to properly switch them off at the moment until the issue is resolved.
Is this symptom occurring with iOS or Android?
Any update? I am experiencing this issue with it turning notifications back on when not required.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
