  • 2 Replies
  • 2366 Views
MBL007
Hi, all,
I having a devil of a time adding a friend. I was able to create an account for him after sending the email and accepting the invitation. I deleted him as a friend and then tried again - creating an account. It said there already was an account. It then asked me to pair the cameras. Do I need to do that?
Super confused! And, frustrated.
Thanks!
Definitely not.  And you can't, since the cameras can only be installed to one account.
Try sending a fresh invite. Then accept the invite by clicking on "Create account" on a PC.  That will open the browser to my.arlo.com.  From there log into the friend's existing account - do NOT create another one.  You need to fully log in - completing the two-factor authentication step.
After that is done, look in your account and make sure you see the invitation status as accepted.
The friend's account will have two "Home" locations - yours, and their own.  They need to select your home location to see your cameras.  This is confusing, so you should try renaming their empty "home" location to something else.
MBL007
Thanks! That worked!
