No alerts and no video recording
  • 11 Replies
  • 2185 Views
DavidCooper
For the last month, I have been having issues with no recordings and no alerts. I have tried everything from factory resets to a full uninstall and reinstall of the app, but I'm still not getting any alerts or recordings.
Is there something I'm missing, or is there another problem with Alro services?
@HLStephenson wrote:
Go to Arlo.com click on support.   I use the live chat. (lower right, box with 3 dots)
Once you make contact with a person they'll open the help ticket for your case.
Or use the support center in the app.
That will give you the option of phone support.
11 REPLIES 11
Did the subscription expire?
DavidCooper
my subscription expires on February 27, 2025
Can you make a manual recording while livestreaming?
DavidCooper
Hi,
Yes i have recorded a 20sec footage which now shows in my feed.
I have seen others with the same problem and looks like Arlo support needs to update something there end
That confirms the subscription status.
Have you double-checked the mode(s) you are using - making sure there is a rule for the camera that is set to notify and record?
DavidCooper
Yes, the away mode is set to record and notify.
HLStephenson
Known issue, contact ARLO support to get a help ticket.  We have been waiting over a month as the "engineers" work on a fix.
DavidCooper
How do you submit a help ticket? i have looked over the website, the app etc but all seem to be less than helpful.
https://kb.arlo.com/000062993/What-is-the-Support-Center-in-the-Arlo-Secure-App-Arlo-Secure-4-0
HLStephenson
