  • 2 Replies
  • 3340 Views
KeysK
I have 2 cameras, one is included within a one camera plan.
The camera on the plan has vanished from my app, as well as associated recordings.
The other camera is still available.
Any ideas?
Does the subscription still show in your account? If so, use the app to go to Settings, Support and choose your camera (or any camera that gets you to the next step). Scroll down to Contacts to talk to official support to see what they can tell you.
Otherwise, all you can do is to try onboarding it again. Use this procedure to reset the camera before doing so.
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
KeysK
Thanks. Factory reset and re-adding the camera has worked.
