Looking for 4 outdoor WiFi, wired cameras.
  • 641 Views
CameraTypes
Hi everyone.
Poting my question here because there are so many options I don't know which camera is best or my needs.
I want to install 4 or 5 outdoor security cameras. WiFi is not an issue but I do not want to use batteries and would prefer to wire the cameras to outlets behind the vinyl siding and / or through the soffit(s). I would like the best resolution possible and best picture clarity at night. I don't care about 2-way conversations or lights but they're not deal breakers.
Ideally, I would love to be able to store video and sound locally instead of on Arlo's subscription-based cloud service, but that's also not a deal breaker for me. The real stickler is I don't want to use batteries.
Can anyone make a recommendation?
Are you ok with having the batteries installed, as long as you can power the cameras from the outlets?
CameraTypes
Hi StephenB.
I just don't want to go outside on a ladder and swap batteries when they run out.
Can cameras come with batteries and a wire for charging?
Yes.  There is an outdoor rated charger (integrated cable+power adapter) available for all the Arlo cameras.  The cable is 25 feet, which likely is more than you will need - so you would need to have some way to take up the slack.  If the cameras and power outlet are protected from whether you could also try the indoor charger.
Personally I put my cameras where I can reach them easily.  They do occasionally need to be reset or restarted, so I like to have them accessible.
Also, the motion detection range is only 20-25 feet, so keep that in mind when you plan out their locations.
As far as models go, the basic options are the
  1. Essential Gen 2 2K
  2. Pro 3/Pro 4/Pro 5
  3. Ultra
The Gen 2 model is the least expensive and charges over USB-C.  The battery is fully sealed, and not user replaceable.  The main drawbacks here are that the camera is fairly new, and I think there are some issues that still need to be worked out and fixed with firmware.  Also, it is missing a couple of features (smarthub support and homekit).
The three Pro models are quite similar - I think the Pro 3 and Pro 4 are being discontinued.  The Pro 3 requires a smarthub, the Pro 4 and Pro 5 can be connected to your home wifi.  All have user-replacable batteries. All use a proprietary magnetic connector - which is a bit bulky, so it will require a bigger hole in the siding than the USB-C connector.
The Ultra is the only 4K model, and is the oldest currently sold Arlo camera.  It uses the same cables and battery as the Pro models, and requires a smarthub.
All require a subscription for cloud storage and smart notifications.
Given that you are hard-wiring the cameras and are worried about accessing them, you might also look at other manufacturers who offer power-over-ethernet cameras.  These usually also require some in-home equipment (a PoE switch and PC to manage the cameras, store the videos, etc).  I don't have any cameras like that, so I have no suggestions to offer.
