Looking for 4 outdoor WiFi, wired cameras.
Hi everyone.
Poting my question here because there are so many options I don't know which camera is best or my needs.
I want to install 4 or 5 outdoor security cameras. WiFi is not an issue but I do not want to use batteries and would prefer to wire the cameras to outlets behind the vinyl siding and / or through the soffit(s). I would like the best resolution possible and best picture clarity at night. I don't care about 2-way conversations or lights but they're not deal breakers.
Ideally, I would love to be able to store video and sound locally instead of on Arlo's subscription-based cloud service, but that's also not a deal breaker for me. The real stickler is I don't want to use batteries.
Can anyone make a recommendation?
Are you ok with having the batteries installed, as long as you can power the cameras from the outlets?
Hi StephenB.
I just don't want to go outside on a ladder and swap batteries when they run out.
Can cameras come with batteries and a wire for charging?
Yes. There is an outdoor rated charger (integrated cable+power adapter) available for all the Arlo cameras. The cable is 25 feet, which likely is more than you will need - so you would need to have some way to take up the slack. If the cameras and power outlet are protected from whether you could also try the indoor charger.
Personally I put my cameras where I can reach them easily. They do occasionally need to be reset or restarted, so I like to have them accessible.
Also, the motion detection range is only 20-25 feet, so keep that in mind when you plan out their locations.
As far as models go, the basic options are the
- Essential Gen 2 2K
- Pro 3/Pro 4/Pro 5
- Ultra
The Gen 2 model is the least expensive and charges over USB-C. The battery is fully sealed, and not user replaceable. The main drawbacks here are that the camera is fairly new, and I think there are some issues that still need to be worked out and fixed with firmware. Also, it is missing a couple of features (smarthub support and homekit).
The three Pro models are quite similar - I think the Pro 3 and Pro 4 are being discontinued. The Pro 3 requires a smarthub, the Pro 4 and Pro 5 can be connected to your home wifi. All have user-replacable batteries. All use a proprietary magnetic connector - which is a bit bulky, so it will require a bigger hole in the siding than the USB-C connector.
The Ultra is the only 4K model, and is the oldest currently sold Arlo camera. It uses the same cables and battery as the Pro models, and requires a smarthub.
All require a subscription for cloud storage and smart notifications.
Given that you are hard-wiring the cameras and are worried about accessing them, you might also look at other manufacturers who offer power-over-ethernet cameras. These usually also require some in-home equipment (a PoE switch and PC to manage the cameras, store the videos, etc). I don't have any cameras like that, so I have no suggestions to offer.
"Sync software update"
180 degree
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
smart things
Unknown charges
VMC3050
